poIStressLinearizationCtrl IsDatatypeCompatible
Checks to see if the specified datatype can be used for Stress Linearization.
poIStressLinearizationCtrl_handle IsDatatypeCompatible datatype
HyperView Tcl Query
This command checks to see if the datatype can be used for Stress Linearization.
- datatype
- The date type.
To check to see if the specified datatype can be used for Stress
Linearization:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl IsDatatypeCompatible data_type
hwi CloseStackErrors
None.
