poIStressLinearizationCtrl SetReportFile
Sets the path for the CSV report.
poIStressLinearizationCtrl_handle SetReportFile report_file
HyperView Tcl Modify
This command sets the path for the CSV report. The default value is <model_path>/<model_name>.csv.
- report_file
- The name of the report file.
To set the path for the CSV
report:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetReportFile report_file
hwi CloseStackErrors
None.
