poIStressLinearizationCtrl SetPlotWindow
Sets the plot window ID. This window will be used to plot curves.
poIStressLinearizationCtrl_handle SetPlotWindow windowID
HyperView Tcl Modify
This command sets the plot window ID. This window will be used to plot curves.
- windowID
- The window ID.
To set the plot
window:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetPlotWindow window_id
hwi CloseStackErrors
None.
