poIStressLinearizationCtrl RemoveSCL
Deletes the Stress Characterization Line (SCL) specified by ID.
poIStressLinearizationCtrl_handle RemoveSCL id
HyperView Tcl Modify
This command deletes the Stress Characterization Line (SCL) specified by ID.
- id
- The ID of the Stress Characterization Line (SCL).
To delete a Stress Characterization Line
(SCL):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl RemoveSCL scl_id
hwi CloseStackErrors
None.
