poIStressLinearizationCtrl SetComponentsToPlot
Specifies the tensor components to be included in the HyperGraph plot.
poIStressLinearizationCtrl_handle SetComponentsToPlot compsToPlot
HyperView Tcl Modify
This command specifies the tensor components to be included in the HyperGraph plot. The default value is XX YY ZZ XY YZ ZX.
- compsToPlot
- The tensor components to be included in the plot.
To specify the tensor components to be included in the HyperGraph
plot:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetComponentsToPlot compsToPlot
hwi CloseStackErrors
None.
