Extend
Extend or shorten an entity of a sketch curve.
Click the Extend icon.
Click an entity to select it.
Tip: When surface is selected, you can select Imprint on Surface on the guide bar to auto-imprint or trim the sketch onto the surface.
Move the mouse to preview the extended or shortened entity, and then click to
extend or shorten the entity.
Tip: If in the previous step you selected an entity (A) that intersects with another entity (B), you can click B near the intersection point to extend or shorten A at that intersection point.
Table 1. Example 1: Extend Figure 1. Select Entity "A" (Line)
Figure 2. Click Entity "B" (Arc) Near the Intersection Point
Figure 3. "A" Is Extended to the Intersection Point
Table 2. Example 2: Shorten Figure 4. Select Entity "A" (Line)
Figure 5. Click Entity "B" (Arc) Near the Intersection Point
Figure 6. "A" Is Shortened at the Intersection Point
Tip:
- This tool does not currently work on Splines.
