2025
Explore the different types of 3D mesh you can create in HyperMesh.
Explore the tools used to edit 3D mesh.
View new features for Altair HyperWorks 2025.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Explore the different types of 2D mesh you can create in HyperMesh.
Supported 3D elements.
Explore the tools used to create 3D mesh.
Explore the tools used to create solid mesh.
Use the Boolean tool to combine solids, subtract one solid from another, and find the intersection out of the solids.
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
The Solid Mesh Optimization tool can be used to improve the quality of a tetra, hexas, and second order meshes with respect to several element criteria.
Connect intersecting triangular and quadrilateral 2D elements.
The Developer ribbon contains tools for automation and customization.
