Flexbody solved in MotionSolve
- From the Select application menu, select HyperView.
- From the Home tools, Files tool group, click the Open Model tool.
From the Load Model panel, verify that the Load model and Load results check
boxes are activated.
Click the Load model file browser
The Load Model File dialog is displayed. -
Open the .h3d result file.
The same file is automatically loaded into the Load results field.
- Click Apply.
