2025
Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
Supported finite element entities.
View new features for Altair HyperWorks 2025.
Assemblies collect and organize sub-assemblies and components into hierarchical data structures which are intended to reflect the data structure of the product being modeled.
Components collect and organize points, lines, surfaces, solids, elements and connectors. Components are intended to be organizational containers for the geometry and FE idealization of a physical part which makes up a product.
Bags collect and organize entities.
Entities which are given a name but are not collected or organized into containers.
Entities used for morphing the shape of FE model.
Entities used to set up optimization problems.
Control card entities create solver control cards such as results file I/O options, CPU and memory limits, and others.
Undefined entities are entities that will not be written to the solver deck.
The encryption of solver entities is used to translate entity data into an undisclosed language.
Element property and material assignment rules are based on the current user profile (solver interface).
Supported cards organized by solver.
The Developer ribbon contains tools for automation and customization.
