HyperGraph hgradioss External Reader
| Description | Supports | Does Not Support |
| Reads Radioss T01 files (result files generated by the solver) into HyperGraph. | Global
Variables PARTS PROP MAT NODE BRIC QUAD SHEL, SH3N BEAM TRUSS SPRING ACCEL SECTIO CYL_JO MONV RWALL RBODY INTER SUBS |
NSTRAND |
Usage
To run from the command
prompt:
hgradioss(.exe) –f fileT01 outfileTo run in HyperGraph:
By default, this reader is registered. If not, register it before reading T01 files directly into HyperGraph. It is located in the HWDIR\externalreaders\ directory.
Notes
- HyperGraph supports T01, T01a, ….. T01i time history files
- HyperGraph supports _0001.thy, _0001a.thy, …._0001i.thy time history files
- HyperView support #T01, @T01 files from RAD2NOISE tool
- HyperView support .lst files from HELIOSS
