Create Predefined Report
Tutorial Level: Beginner
In this tutorial, you will learn how to create, execute, and export predefined report
using the Report ribbon options- Session Report and Model Summary Report.
Note: This
tutorial is applicable only for HyperMesh
client.
Before you begin, copy the file(s) used in this tutorial to your working
directory:
- Start HyperMesh.
- Open the Report ribbon.
From the menu bar, select .
The Open Session File dialog opens.
Browse and select the Report_Tutorial_Session.mvw
file.
The file opens in the graphics window.
- From File menu, click Preferences.
Select Report from Common section.
- Edit the Default Report Type and Document Layout preferences.
From the Predefined group, click
- Select the type of the report: Presentation, HTML or Document.
Click Export
The Session Report is saved in the given directory.
From the Predefined group ribbon, click Model
Summary.
Figure 3.
Select the Model Description details as applicable.
Figure 4.
- Optional:
Click Interactive for interactive report generation.
Figure 5.
Note: The report tree should be active for Interactive Report generation. -
Click Export.
The Model Summary report is saved in the given directory.
