Edit Layout Templates
To edit layout templates, follow the below steps:
- Copy the folder templates from ALTAIR_HOME\hwdesktop\mv\scripts\tcl\report\ to a new directory.
Edit Document Layout Template
- Open wordTemplate from templates folder.
Edit the following mandatory place holders:
- Table of contentsNote: When exporting a Document report, a Word processing application is required to auto-update the Table of Contents.
- Table of figures
- Table of tables
- Table of references
- Style formats (available in the Styles ribbon)
- Table of contents
Edit Presentation Layout Template
- Open pptTemplate from templates folder.
Edit the following placeholders:
- Slide Template Layouts- Presentation Layout
template based on Slide Master Layouts must contain placeholders for the
following elements:
- Slide masters
- Secondary slides with image, text, and table placeholders
- Slides with Existing Content - Presentation Layout template based on slides with existing content must contain sample images, text, and table data. This sample data will later be replaced while exporting a report.
- Slides with Generic Placeholders - Generic placeholders for image, text, and table placeholders. This allows you to open the Presentation reports in open source applications such as Google Docs and LibreOffice.
Tip: While creating a layout, follow a sequence for creating the content placeholders. You can use the Edit Master feature in the respective applications.You may arrange the content (image, text, or table) shapes in your application by dragging text within the selection pane or using the right-click context menu. By default, a newly added item appears at the top of the list. Use the Z-Order technique for arranging the shapes in the slides.
During Presentation export, order is decided based on the list in selection pane.Figure 1.
following elements:
Edit HTML Layout Template
Open the Index_Layout.html file from
htmlTemplate folder. The following placeholders are
editable in Index_Layout.html:
- REPORT_TITLE
- REPORT_TOC
- REPORT_CONTENT
Change the logo and disclaimer statement in the
Index_Layout.html file.
Edit the style.css in the resource folder for modifying
the properties of each placeholder. For instance, to modify the REPORT_TITLE
navigate to
report-titleclass in the style.css file and edit the values for properties such as color, font and width as shown below:Figure 3.
