Change Reporting Default Preferences
To change the default preferences of report, follow the below steps:
- From File menu, click Preferences.
Under Common, select Report.
- Select the Default report type - Document, Presentation.
- Select the Layout Templates for Presentation, Document, and HTML reports.
- Select the Image or Video resolution.
Select the default File path storage:
- Relative: Relative to the report template path.
- Absolute: Actual path of the file.
- Optional: Select Open report after export.
- Optional: Select Use aspect ratio as per PPT placeholder. This applies to only Presentation reports.
- Click OK.
