Mesh Quality Statistics
Creates a table of mesh quality parameters defined in criteria settings file.
From the Report Ribbon, Add Modules tool group, click
and select
module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Mesh Quality Statistics module.
- Name
- Provide the name for the Model Quality Statistics module.
- Model
- Provide the location of the model in the list of HyperMesh windows in the session.
- Basic
- Select 2D or 3D or both elements for Mesh quality checks.
- 2D Quality Checks
- Select the required quality check parameters.
- 2D Mesh Categories
- Select the required mesh categories such as ideal, good, warm,fail and worst.
- 3D Quality Checks
- 3D Mesh Categories
and worst.Note: User can edit in the mesh quality criteria also in Criteria File Settings in Preferences.
- Advanced
- Numeric Precision
- Select the number of decimal places.
- Numerical Format
- Select the numerical formats- Fixed, Scientific and Engineering.
- Auto Split Table
- Provides the function to split up tables automatically based on the space available in the slide or page.
- Once executed, a table output for Mesh Quality Statistics is generated:
