Model Size and Dimensions
Creates three table outputs including - overall model dimension, centre of gravity and inertia of the model and model mass.
From the Report Ribbon, Add Modules tool group, click
and select
module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Model Size and Dimensions module.
- Name
- Provide the name for the Model Size and Dimensions module.
- Model
- Provide the location of the model in the list of HyperMesh windows in the session.
- Basic
- Select the Model Mass, Model Dimensions and; Centre of Gravity and Inertia.
- Advanced
- Numeric Precision
- Select the number of decimal places.
- Numerical Format
- Select the numerical formats- Fixed, Scientific and Engineering.
- Auto Split Table
- Provides the function to split up tables automatically based on the space available in the slide or page.
- Once executed, a table output for Model Dimensions is generated:
