License Usage Logs
Request for license level logs for the last 30 days, from the current year to date or for a specific date range.
Click Usage Logs.
The License Usage Logs form is displayed.
Figure 1. License Usage Logs
- Select the required license as License ID from the drop down list.
Select Date Range to specify the start and end date. Use
to select the start and end date.
- Optional:
Select Anonymize Logs.
The logs will not contain any personally identifiable information.
- Optional:
Select Parse Logs to utilize the transactional log
parser which createa output files based on the selected options.
- The Duration Units refers to the time measurement used for the records. By default, it is set to minutes, but it can be adjusted to hours or seconds as needed.
- The Post Process performs a secondary processing run, generating an additional CSV file following the pattern: extended_output_file. This file includes extra columns for the associated tracking feature, GlobalZone, and duration units usage.
- The EOW should be used to close all open transactions as of the time indicated in the last log file.
- The Split will split the transactions that cross a day boundary into multiple records, one for each day.
- The Single will create multiple files one for each input log file.
Click Submit.
A confirmation message is displayed about the log request.
