BAR_CHART
Bar chart of specified quantities.
BAR_CHART(“name”) {parameters}
Qualifier
User-given name
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- data_source (enum)
- Options: file, ufx_coefficients_file
- data_file (string)
- Path to location of data source file
- background_image_show (boolean)
- Option to turn on the background image added to the bar chart
- background_image (string)
- Image to be displayed in the background
- background_image_view (string)
- View of image to be displayed in the background
- num_header_rows (integer)
- Number of header rows to ignore before reading in data
- output_step (integer)
- Data step to use for plot
- target_names (array)
- List of strings containing part names from which you want to extract results, may utilize “_all” to plot all part names contained in the input file. Wildcard “*” may be used when defining the target_names
- max_result_count (integer)
- Maximum number of data points to include
- name_column (integer)
- Column number which contains the names
- data_column (integer)
- Column number which contains the values
- x_label (string)
- Label for the x-axis
- y_label (string)
- Label for the y-axis
- title (string)
- Title for the plot
- show_legend (boolean)
- Show the legend or not
- legend_labels (string)
- Labels for use in the legend
BAR_CHART("Cd bar chart - file"){
data_source = "file"
data_file = "uFX_coefficientsData\uFX_coefficientsPerPart_Inst.txt"
num_header_rows = 6
name_column = 2
data_column = 3
output_step = 0
y_label = "C_d"
target_names = {"*Tire*","*Wheel*"}
