VARIABLE
Expressions are used to define a quantity in terms of variables that are defined using the VARIABLE command or in terms of built in math functions (sin, cos, tan, and so on). The order in which commands appear is not important. Variable x could be a function of variable y, even though it appears afterward in the input file.
VARIABLE {parameters}
Qualifier
This command has no qualifier.
variable_name (string)
Given name of the variable
expression (string)
Number or mathematical expression that defines this variable
VARIABLE{
variable_name = meanVel
expression = 0.2265
VARIABLE{
variable_name = nSeeds
expression = 15
VARIABLE{
variable_name = Vehicle_xMin
expression = -0.90743399
VARIABLE{
variable_name = xStart
expression = Vehicle_xMin
VARIABLE{
variable_name = xSpacing
expression = 0.2
VARIABLE{
variable_name = xEnd
expression = Vehicle_xMax+xSpacing
Commands/Attributes Supported
Expressions will be evaluated as numerical values when they are used for the attributes in these commands:
  • Set up commands:
    • DATASET
    • DISPLAY
    • VIEWANGLES
    • VIEW
  • In object commands:
    • PART
    • GEOMETRY
    • CUT_PLANE
    • ISO_SURFACE
    • STREAMLINE
Such attributes include:
  • real type:
    • cut_location
    • density
    • iso_value
    • legend_max
    • legend_min
    • mean_velocity
    • transparency
    • threshold_min
    • threshold_max
    • viscosity
    • x_1
    • x_2
    • x_center
    • x_length
    • x_min
    • x_max
    • y_1
    • y_2
    • y_center
    • y_length
    • y_min
    • y_max
    • z_1
    • z_2
    • z_center
    • z_length
    • z_min
    • z_max
  • integer type:
    • num_contours
    • num_labels
    • num_seeds
    • x_seeds
    • y_seeds
    • z_seeds
  • Additionally, in IMAGE command, the following attributes will also trigger the evaluation of the expressions:
    • sweep_range
    • zoom_factors
