SURFACE_STREAMLINE
Surface streamlines are massless particles moving along the surface of an object or plane with a velocity tangent to the streamline at every point.
SURFACE_STREAMLINE(“name”) {parameters}
Qualifier
User-given name
name (string)
User-given name of the command. The instance of a given command is referenced using this parameter.
seed_type (enum)
Defines the type of seeding operation
Options: from_surface, from_file.
surface_type (enum)
The type of surface that the surface_streamlines will be defined on. Note that the Part or Cut_Plane that the surface streamlines are drawn on must be created, using the Image command.
Options: parts (default), cut_planes.
cut_planes (list)
Cut planes to seed, used when surface_type=cut_planes.
List provided as comma separated values within curly braces. {“cut_plane_1”, “cut_plane_2”}
parts (list)
Parts to seed, used when surface_type=parts.
List provided as comma separated values within curly braces. {“part_1”, “part_2”}
calculation_direction (enum)
Defines the calculation direction for the streamline calculation.
Options: forward (default), backward or both.
num_seeds
(integer) Number of seeds to use when seeding the surface streamlines
seed_file (string)
Absolute or relative path and file name to the seed file, defines the x, y, z locations of the seeds to be used for streamline generation. Used when seed_type=from_file.
vector_function (string)
Vector field to define the streamline computation (velocity, time_avg_velocity, velocity_xz, time_avg_velocity_xz)
line_thickness (enum)
Thickness of lines for streamline display
Options: thin, medium, thick
contour_function (string)
Scalar quantity to be displayed on part (pressure, velocity, etc., Calculate Context Help). Used with color_type=contour.
legend_display (boolean)
Flag to toggle on or off the visibility of the legend
legend_min (real)
Minimum value in legend
legend_max (real)
Maximum value in legend
legend_location (enum)
Location of the legend on the image
Options: top_left, top_center, top_right, bottom_left, bottom_center, bottom_right, center_left, center_right
legend_use_local (enum)
Boolean to control the local legend range. If active, will set for local entity range.
legend_title (string)
Legend name to be used for the provided contour function, defaults to internal name
colormap_name (enum)
Colormap name to use for displaying the scalar function values
Options: Cool to Warm, Cool to Warm (Extended), Black-Body Radiation, X Ray, Inferno, Black, Blue and White, Blue Orange, Viridis, Gray and Red, Linear Green, Cold and Hot, Blue – Green – Orange, Rainbow Desaturated, Yellow – Gray – Blue, Rainbow Uniform, Rainbow, Rainbow Legacy
SURFACE_STREAMLINE("Full Vehicle Surface Streamlines"){
seed_type = from_surface
surface_type = parts
parts = {"Full vehicle - white"}
num_seeds = 6000
vector_function = "time_avg_wall_shear_stress"
calculation_direction = both
color_type = contour
contour_function "time_avg_skin_friction_coefficient"
colormap_name = "Inferno"
legend_display = on
legend_title = "Cf (time-averaged)"
legend_min = cf_min
legend_max = cf_max
legend_location = top_center
legend_orientation = horizontal
SURFACE_STREAMLINE("Y-Slice Time Average Cv - Surface Streamlines"){
surface_type = cut_planes
num_seeds = 600
vector_function = "time_avg_velocity"
cut_planes = {"Y-Slice Time Average Cv - Contour"}
color_type = constant
constant_color = "black"
IMAGE("Y-Slice Time Average Cv - Streamlines"){
parts = {"Full vehicle - white - 0.5 transparent"}
surface_streamlines = {"Y-Slice Time Average Cv - Surface Streamlines"}
views = {"right"}
focal_parts = {"Full vehicle - white - 0.5 transparent"}
zoom_factors = {y_slice_zoom_factor}
sweep_planes = {"Y-Slice Time Average Cv - Contour"}
image_type = cut_plane_sweep
sweep_range_type = direct
sweep_range = yStart:yEnd:ySpacing
image_savetype = images
clip_parts = on
reverse_clip_direction = on
