Image is used to capture image of specified quantity.
IMAGE(“name”) {parameters}
Qualifier
User-given name
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- cut_planes (string)
- Cut planes to include in the image. List provided as comma separated values within curly braces.
- parts (string)
- Parts to include in the image. List provided as comma separated values within curly braces.
- iso_surfaces (string)
- Iso surfaces to include in the image. List provided as comma separated values within curly braces.
- streamlines (string)
- Streamlines to include in the image. List provided as comma separated values within curly braces.
- surface_streamlines (string)
- Surface streamlines to include in the image. List provided as comma separated values within curly braces.
- focal_parts (string)
- List of focus parts to focus on during image creation. Requires that the PART command be created prior to calling the IMAGE command. List provided as comma separated values within curly braces.
- zoom_factors (string)
- List of zoom factors to zoom into (out from) the focal_part, where >1.0 will zoom in, <1.0 will zoom out. List provided as comma separated values within curly braces.
- image_type (enum)
- Type of images to be generated
- image_savetype(enum)
Type of output format to be generated, series of images or a single movie. Used when image_type = cut_plane_sweep or animation
- views (string)
- Views to capture the image from. List provided as comma separated values within curly braces. Available views: "left", "right", "front","rear", "top","bottom", "front_bottom", "rear_bottom", "front_top", "rear_top", "front_left", "front_right", "rear_left", "rear_right", "front_left_bottom", "rear_left_bottom", "front_right_bottom","rear_right_bottom","front_left_top","rear_left_top", "front_right_top", "rear_right_top", "left_top","right_top", "left_bottom","right_bottom"
- sweep_planes (string)
- Planes to use in sweep. List provided as comma separated values within curly braces.
- sweep_range (sequence)
- Colon separated values to define the start:end:increment, e.g. 0.0:5.0:0.25
- clip_parts (boolean)
- Clips part at location of sweep plane
- reverse_clip_direction (boolean)
- Reverses direction of clip part
- start_frame (integer)
- The solution step that marks the beginning of the animation.
- end_frame (integer)
- The solution step that marks the end of the animation.
- frame_increment (integer)
- The stride to take while sweeping through the solution steps.
- frame_rate (integer)
- The frame rate to control playback of the animation. Used only when creating mp4 files.
- export (boolean)
- Exports data from derived representations from the report automation tool. Stores the physical coordinates along with the variables that are contained within the dataset.
- export_type (string)
- Sets the filetype to be exported.
Examples
IMAGE("Solid blades with mesh, transparent walls"){
parts = {"Inlet - solid - transparent","Blades - solid","Blades - mesh",
"Tube - solid - transparent", "Outlet - solid - transparent","Tube - outline"}
views = {"front_left_top", "front_left_top", "Blade iso","Blade iso", "Downstream iso", "Downstream iso"}
image_type = static
IMAGE("Cut plane time animation"){
cut_planes = {"z-plane","User CP 1", "User CP 2", "User CP 3"}
parts = {"all - outline"}
views = {"iso view","+z"}
zoom_factors = {1,0.9}
image_type = animation
start_frame= 1
end_frame= 10
frame_increment = 4
frame_rate = 5
IMAGE("CUTPLANE1"){
parts = {"Full vehicle - white - transparent"}
cut_planes = {"Y normal - inst_velocity_mag"}
export = off
export_type = csv
An animation is created for each view that is listed in the views parameter. The frame_rate option is only valid when the image_type=animation or cut_plane_sweep. The option will modify the frame rate defined within the .mp4 (default) or .avi file that is created.
Animations are automatically embedded into the ppt files.
