LINE_PLOT
Graphical 2D plot of quantities.
LINE_PLOT(“name”) {parameters}
Qualifier
User-given name
name (string)
User-given name of the command. The instance of a given command is referenced using this parameter.
data_source (enum)
Options: file, ufx_coefficients_file
data_file (string)
Path to location of data source file
background_image_show (boolean)
Option to turn on the background image added to the bar chart
background_image (string)
Image to be displayed in the background
background_image_view (string)
View of image to be displayed in the background
num_header_rows (integer)
Number of header rows to ignore before reading in data
output_step (integer)
Data step to use for plot
0 = use last, -1 = second from last, 1 means first, and so on
x_column (integer)
Number of column to plot on the x-axis
y_columns (integer list)
Number of column/columns to plot on the y-axis
x_label (string)
Label for the x-axis
y_label (string)
Label for the y-axis
title (string)
Title for the plot
show_legend (boolean)
Show the legend or not
legend_labels (string list)
Labels for each curve for use in the legend
show_grid (boolean)
Show grid in plot area
LINE_PLOT("Sectional C_d and C_l With Background Image"){
data_source = "ufx_coefficients_file"
data_file = "./uFX_coefficientsData/uFX_coefficientsPerSectionX_Inst.txt"
num_header_rows = 5
x_column = 3
y_columns = {4,5}
output_step = 0  # 0 = use last, -1 = second from last, 1 means first, etc.
x_label = "Section Center (m)"
y_label = "Cumulative C_d and C_l"
title = "Cumulative Lift and Drag Coefficients"
legend_labels = "C_d,C_l"
show_legend = on
show_grid = on
background_image = "Surface geometry"
background_image_view = “left”
