STREAMLINE
Streamlines are massless particles moving along a path with a velocity tangent to the streamline at every point.
STREAMLINE(“name”) {parameters}
Qualifier
User-given name
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- seed_type (enum)
- Method of identifying seed locations
- normal_direction (enum)
- Cartesian direction used to cut the volume data with specified plane cut_location
- calculation_direction (enum)
- Defines the calculation direction for the streamline calculation.
- x_center (real)
- x-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- y_center (real)
- y-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- z_center (real)
- z-coordinate of centerpoint of rectangle. Used when seed_type=rectangular.
- x_length (real)
- Length of rectangle in the x direction. Used when seed_type=rectangular.
- y_length (real)
- Length of rectangle in the y direction. Used when seed_type=rectangular.
- z_length (real)
- Length of rectangle in the z direction. Used when seed_type=rectangular.
- x_seeds (integer)
- Number of seeds equally spaced along the rectangle in the x direction. Used when seed_type=rectangular.
- y_seeds (integer)
- Number of seeds equally spaced along the rectangle in the y direction. Used when seed_type=rectangular.
- z_seeds (integer)
- Number of seeds equally spaced along the rectangle in the z direction. Used when seed_type=rectangular.
- x_1 (real)
- x location of first seed of rake. Used with seed_type = rake.
- y_1 (real)
- y location of first seed of rake. Used with seed_type = rake.
- z_1 (real)
- z location of first seed of rake. Used with seed_type = rake.
- x_2 (real)
- x location of second seed of rake. Used with seed_type = rake.
- y_2 (real)
- y location of second seed of rake. Used with seed_type = rake.
- z_2 (real)
- z location of second seed of rake. Used with seed_type = rake.
- num_seeds (integer)
- Number of seeds to place between two specified points for rake
- seed_file (string)
- Absolute or relative path and file name to the seed file, defines the x, y, z locations of the seeds to be used for streamline generation. Used when seed_type=from_file.
- color_type (enum)
- Method used to set the display color.
- constant_color (enum)
- Display the streamlines as a constant color
- contour_function (string)
- Scalar quantity to be displayed on the streamline (pressure, velocity, etc., see Calculate Context Help). Used with color_type=contour.
- vector_function (string)
- Vector field to define the streamline computation (velocity, time_avg_velocity, velocity_xz, time_avg_velocity_xz)
- line_thickness (enum)
- Thickness of lines for streamline display.
- legend_display (boolean)
- Flag to toggle on or off the visibility of the legend
- legend_min (real)
- Minimum value in legend
- legend_max (real)
- Maximum value in legend
- legend_location (enum)
- Location of the legend on the image
- legend_use_local (enum)
- Boolean to control the local legend range. If active, will set for local entity range.
- legend_title (string)
- Legend name to be used for the provided contour function, defaults to internal name.
- colormap_name (enum)
- Colormap name to use for displaying the scalar function values
STREAMLINE("upstream rake"){
calculation_direction = forward
seed_type = rake
normal_direction = x
x_1 = (xMax-xMin)*.2 + xMin
y_1 = yMax*.99
z_1 = (zMax-zMin)/2.0 + zMin
x_2 = (xMax-xMin)*.2 + xMin
y_2 = yMin*.99
z_2 = (zMax-zMin)/2.0 + zMin
num_seeds = nSeeds
line_thickness = thin
color_type = contour
contour_function = "velocity_magnitude"
legend_display = on
vector_function = "velocity"
legend_use_local = off
legend_min = .6*meanVel
legend_max = 2.5*meanVel
legend_title = “Velocity Magnitude (m/s)”
IMAGE("Full vehicle streamlines"){
parts = {"Full vehicle - white"}
streamlines = {" upstream rake "}
image_type = static
views = {"front_left_top","rear_left_top","left","front_left_bottom","front_right_bottom"}
focal_parts = {"Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white","Full vehicle - white"}
zoom_factors= {1.2,1.2,1.5,1.2,1.2}
STREAMLINE("Vortex Core Streamlines"){
display_seeds = off
seed_type = from_file
seed_file = "VC_Seeds.csv"
line_thickness = medium
vector_function = "time_avg_velocity"
contour_function = "time_avg_velocity"
legend_display = on
legend_location = top_center
legend_orientation = horizontal
legend_min = 0
legend_max = meanVel
colormap_name = "Rainbow Desaturated
IMAGE("Vortex Core seeded streamlines"){
Parts = {"Full vehicle - white"}
streamlines = {"Vortex Core Streamlines"}
image_type = static
views = {"front","front_left_top","rear_left_top","rear","top","left","bottom","front_left_bottom","front_right_bottom"}
zoom_factors = {2.0,1.2,1.2,2.0,1.5,1.5,1.5,1.2,1.2}
