Configuration File
The configuration file (feconfig.cfg) is used to define the structure of the realization.
Element Structure
Weld definitions are solver dependant (OptiStruct, Radioss, and so on). The specific solver template for the type of weld must be loaded before the welds can be created using a connector entity.
The configuration file can be manually loaded via the Control Manager.
The configuration file can be automatically loaded when HyperMesh launches. When launched, HyperMesh searches for the feconfig.cfg
file in the following locations. The locations below are listed in search order.
- <install_directory>/hwdesktop/hw/bin/win64
- HW_CONFIG_PATH (a specified environment variable)
- Your home directory (for example, in UNIX)
- The current working directory
Weld Definition Template
All the configurations follow the same template.
Each *
flag is explained in detail below.
CFG <SOLVER> <USER_FE_TYPE> <USER_FE_NAME>
*filter <CE_TYPE>
*style <STYLE_TYPE> <STYLE_NUM>
*head
<HM_FE_CONFIG> <HM_FE_TYPE> <RIGID_FLAG> [<DOFS>]
*bodyext <BODY_FLAG>
*body <BODY_FLAG>
<HM_FE_CONFIG> <HM_FE_TYPE> <LENGTH_LOCATION_FLAG> [<DOFS>]
[<HM_FE_CONFIG> <HM_FE_TYPE> <LENGTH_LOCATION_FLAG> [<DOFS>]]
*post <POST_SCRIPT_NAME>
*calcmethod <CALCULATION_METHOD>
SOLVER
- The solver template for which FE needs to be created. Supported solvers are: Abaqus, ANSYS, LS-DYNA, Nastran, OptiStruct, or PAM-CRASH.
USER_FE_TYPE
- A unique (with respect to a solver) user-defined configuration
type ID. User-defined
CFG
s should use numbers greater than 10,000 to ensure no collisions with future native HyperMeshCFG
s. USER_FE_NAME
- The user-specified name for the FE configuration. The specified name is saved and displayed in the Connector Browser.
*filter <CE_TYPE>
*filter <CE_TYPE>
can be used to allow only the specified connector types to realize the configuration.*style <STYLE_TYPE> <STYLE_NUM>
- The
*style
option indicates that the configurations have specific behaviours associated during realization, and that they are native types. *head
- The
head
string is required to specify that a rigid, 1D, or contact is to be created to connect the weld node to the surrounding shell element. *bodyext
- The
bodyext
string is required to specify that the body of a weld has an extension associated with it. Currently, this extension can be created by a group of weld elements protruding at a distance of 0.5*times the thickness of the connected shell elements.*bodyext
lines may be followed by one or moreHM_FE_CONFIG
lines. *body
- The
*body
string is required. *post
- The lines are optional, but if specified it must be followed by the name
(excluding path) of a valid TCL script with a .tcl extension. This TCL script must
be located in, and will be searched in, the following order:
- Current working directory
- Paths in
HW_CONFIG_PATH
environment variable - Installation directory
- hm/bin directory
- hm/scripts directory
- hm/scripts/connectors/ directory
*calcmethod
- The
*calcmethod
tag can be used to define any valid custom realization (points/fasteners) to have a calculation method.
FE Specification Rules
- Each solver will have a specific definition so the same user-defined types can be repeated for each solver.
- 1D and 3D element combinations are not supported.
- The total length of series welds cannot exceed 1.0 (100%). Hence, there cannot be three welds specified in a series with a length factor of 0.5 (50%) each.
- Series and parallel weld element combinations are not supported. Series welds are not supported where the link entities are coincident.
- Series welds are not created when the distance between the connecting link entities is zero.
- Your comments should start with a hash character: #.
