Split with Nodes
Use the Split/Stitch tool to split surfaces using ordered (node list/path) and non-ordered node selections or FE edges.
Note: This tool is supported for FE geometry.
From the Topology ribbon, click the Split/Stitch tool.
From the guide bar, select
Split.
Tip: You can use the keyboard shortcuts underlined in the function name to select a function.
- Optional:
Select surfaces to split.
Note: Target surface selection on the guide bar is optional if only two nodes are selected. If selecting a node list or node path with two or more nodes, you should select the target on the guide bar before selecting nodes.
Activate the Tool selector on the guide bar then choose whether to slit with FE edges or
nodes.
If using nodes, make your selection according to the following table.
Option Description Nodes Left-click on two nodes. Node List Left-click on individual nodes to create the desired path. Node Path - Click
on the guide bar to launch the advance selection menu and select by path.
- Left-click to create the path's start and end points. A preview of the path will be displayed.
- Click
On the guide bar, complete one of the following:
- Click
to apply and stay in the tool.
- Click
to apply and close the tool.
- Click
to exit the tool without applying.
- Click
