2025.1
View new features for Altair HyperWorks 2025.1.
Tutorial Level: Beginner In this tutorial, you will create, adjust, and edit mesh.
Tutorial Level: Intermediate In this tutorial, you will learn how to use the BatchMesher tool to create a 2D Mesh and representations.
Tutorial Level: Intermediate In this tutorial, you will learn how to train a machine learning (ML) model and use it to classify parts by grouping them into part sets.
Tutorial Level: Beginner In this tutorial, you will learn how to create and review different kinds of connectors and attachments.
Tutorial Level: Intermediate In this tutorial, you will learn how to create and connect subsystems and attachments.
Tutorial Level: Intermediate In this tutorial, you will learn how to perform an optimization to the number of connectors (welds) in a model, constrained by displacement values for two load cases.
Tutorial Level: Beginner In this tutorial, you will learn how to perform a design of experiments (DOE) using the Design Explorer workflow.
Tutorial Level: Intermediate In this tutorial, you will learn how to use some of the Artificial Intelligence tools exposed in Design Explorer by creating a design of experiments (DOE) and training an ML model using the Design Explorer workflow.
Tutorial Level: Beginner In this tutorial, you will learn how to perform an optimization using the Design Explorer workflow.
Tutorial Level: Intermediate In this tutorial, you will learn how to use subsystem configurations as design variables in Design Explorer.
Tutorial Level: Advanced In this tutorial, you will learn how to use the expertAI tools in Design Explorer by running two optimizations. the first a standard solver-based optimization, and the subsequent one through expertAI to allow for subjective criteria to be considered in the optimization.
Tutorial Level: Beginner In this tutorial, you will learn how to cleanup geometry and conduct midsurfacing.
Tutorial Level: Beginner In this tutorial, you will learn how to load and prepare CAD geometry.
Tutorial Level: Beginner In this tutorial, you will build and assemble a rails model from CAD to connected FE.
Tutorial Level: Beginner In this tutorial, you will learn strategies for penetration checking.
Tutorial Level: Intermediate In this tutorial, you will analyze and query results.
Tutorial Level: Intermediate In this tutorial, you will learn to create tetra meshes using several different methods and tools.
Tutorial Level: Beginner In this tutorial, you will learn how to replace parts by loading updated representation revisions.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
