Options
Action
Choose between the action of showing or isolating the entities that are found.
Show IDs
Enable to show the IDs of the found entities. Disable to clear IDs.
Highlight found entities
When the action is set to Show, this option highlights the found entities.
Note: Only applicable when Attached to is selected.
Save input selection to mark
Save the input selection to mark along with the found entities.
Include tied contact
Include tied contacts when checking for tied connectivity.
Note: Only available in the Abaqus, LS-DYNA, OptiStruct, PAM-CRASH, and Radioss profiles.
Check projection
Check for tied projection.
Include constraints
Include constraints when checking for FE connectivity.
Include fasteners
Include fasteners when checking for FE connectivity.
Note: Only available in the Abaqus profile.
Include rigid bodies
Include rigid bodies when checking for FE connectivity.
Note: Only available in the OptiStruct and Abaqus profiles.
Include constrained rigid bodies
Include the keyword CONSTRAINED_RIGID_BODIES when checking for FE connectivity.
Note: Only available in the LS-DYNA profile.
Include constrained extra nodes
Include the keyword CONSTRAINED_EXTRA_NODES when checking for FE connectivity.
Include LINKS
Include Plinks, Llinks, Elinks, and Slinks elements when checking for FE connectivity.
Note: Only available in the PAM-CRASH profile.
Include realized FE
Find both connectors and realized FE.
Free edges
Find surface edges when finding lines.
Shared edges
Find shared edges when finding lines.
Non-manifold edges
Find non-manifold edges when finding lines.
Suppressed edges
Find suppressed edges when finding lines.
Found nodes
Choose between adding found nodes to mark or marking them as temp nodes.
Search method
Choose between the search method of Sphere or Box, while finding nearby entities.
