BCELL
Bulk Data Entry Defines a cell element.
BCELL EID PID GA GB JRID
BCELL 6 6 233 223 10
EID Unique element identification number.
No default (Integer > 0)
PID Identification number of a PCELL entry.
Integer: Specifies an identification number for this property.
GA, GB Connected grid points at ends A and B. GA is cathode, and GB is anode.
No default (Integer > 0; GA ≠ GB)
JRID Jelly roll ID, which is an element SET ID. The element SET contains all elements of the corresponding battery. The results related to the cell is displayed on the jelly roll.
  1. BCELL elements are working in transient electro-thermal analysis.
  2. This card is represented as a gap or mass element in HyperMesh.
