MODULE
Bulk Data Entry Defines a module Bulk Data Entry.
MODULE | M | S | P | TYPE | LOAD | ELEC | SCALE | METHOD |
MODULE | 1 | 12 | 7 | CURRENT | 100 | 0 | 1 | 1 |
M | Unique Module identification
number. No default (Integer > 0) |
S | Number of Cells in Series within
Module. No default (Integer > 0) |
P | Number of Cells in Parallel within
TYPE | Entity used to define Module Load.
No default |
LOAD | Module Current or Power Load defined:
(Real) No default |
ELEC | Module Load defined:
SCALE | Elemental QVOL Bernardi calculation method:
(Integer) |
METHOD | Cell Ohmic heating method:
(Integer) |
- MODULE Bulk Data Entries are working in transient electro-thermal analysis.
