PCELL
Bulk Data Entry Defining the properties for battery cell elements.
PCELL | PID | MID | |||||||
INITSOC | CELLCAP |
PCELL | 1 | 2 | |||||||
50.0 | 3000.0 |
PID | Unique battery cell element
property identification number. No default (Integer > 0) |
MID | An MCELL entry
identification number that defines material constants of battery
cell elements. MID on PCELL should only refer to MCELL entries. No default (Integer > 0) |
INITSOC | Initial state of charge of the
No default (Real > 0.0) |
CELLCAP | The capacity of the battery
cell. The unit of this quantity is in [electric current * time] No default (Real > 0.0) |
- All battery cell element property entries should have unique identification numbers.
