/FAIL/HOFFMAN
Block Format Keyword Hoffman failure criterion for modeling the failure of composite materials. This criterion is available for solids and shells.
/FAIL/HOFFMAN/mat_ID/unit_ID
σ 1 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ σ 2 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ σ 1 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ σ 2 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ σ ¯ 12 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae badaWgaaWcbaGaaGymaiaaikdaaeqaaaaa@3972@
τ max MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiXdq3aaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3AB9@ Fcut Ifail_sh Ifail_so
Optional Line:
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
σ 1 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ Longitudinal tensile strength.
Default = 1020 (Real)
[ Pa ]
σ 2 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ Transverse tensile strength.
[ Pa ]
σ 1 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ Longitudinal compressive strength.
[ Pa ]
σ 2 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ Transverse compressive strength.
[ Pa ]
σ ¯ 12 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae badaWgaaWcbaGaaGymaiaaikdaaeqaaaaa@3972@ Shear strength.
[ Pa ]
τ max MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiXdq3aaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3AB9@ Dynamic time relaxation. 5
[ s ]
Fcut Shell tensor filtering frequency.
Default = 0.0 (Real)
[ 1 s ]
Ifail_sh Shell failure model flag.
= 0 (Default)
Shell is never deleted and no stress softening.
= 1
Shell is deleted, if damage is reached for one layer.
= 2
Shell is deleted, if damage is reached for all shell layers.
(Integer)
Ifail_so Solid failure model flag.
= 0 (Default)
Solid is never deleted and no stress softening.
= 1
Solid is deleted, if damage is reached for one integration point of solid.
= 2
Solid is deleted, if damage is reached for all integration points.
(Integer)
fail_ID (Optional) Failure criteria identifier. 4
/UNIT/1
                  kg                  mm                  ms
/FAIL/HOFFMAN/1/1
#           SIGMA_1T            SIGMA_2T            SIGMA_1C            SIGMA_2C            SIGMA_12
                 0.6                0.525                 0.8                0.75                0.075
#           TAU_MAX                 FCUT                                 IFAIL_SH            IFAIL_SO
           0.005932                                                              2                    2
  1. This failure model is available for shells and solids. It considers a composite material ply with the fibers oriented in the direction 1 (also denoted m1) and the matrix oriented in transverse direction, that is, in direction 2 (and 3 for solids). Each direction considers a critical strength value in tension and compression as;
    Where, σ 1 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ , σ 2 t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ , σ 1 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ , σ 2 c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaaigdaaeaacaWG0baaaaaa@3998@ , σ ¯ 12 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbae badaWgaaWcbaGaaGymaiaaikdaaeqaaaaa@3972@ are respectively the critical strength in tension for direction 1, in tension for direction 2, in compression for direction 1, in compression for direction 2 and in shear.
  2. The failure criterion for shells is written as:
    F = 1 σ 1 t 1 σ 1 c σ 1 + 1 σ 2 t 1 σ 2 c σ 2 + σ 1 2 σ 1 t σ 1 c + σ 2 2 σ 2 t σ 2 c σ 1 σ 2 σ 1 t σ 1 c + σ 12 2 σ ¯ 12 2 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9maabmaabaWaaSaaaeaacaaIXaaabaGaeq4Wdm3aa0baaSqaaiaa igdaaeaacaWG0baaaaaakiabgkHiTmaalaaabaGaaGymaaqaaiabeo 8aZnaaDaaaleaacaaIXaaabaGaam4yaaaaaaaakiaawIcacaGLPaaa cqaHdpWCdaWgaaWcbaGaaGymaaqabaGccqGHRaWkdaqadaqaamaala aabaGaaGymaaqaaiabeo8aZnaaDaaaleaacaaIYaaabaGaamiDaaaa aaGccqGHsisldaWcaaqaaiaaigdaaeaacqaHdpWCdaqhaaWcbaGaaG OmaaqaaiaadogaaaaaaaGccaGLOaGaayzkaaGaeq4Wdm3aaSbaaSqa aiaaikdaaeqaaOGaey4kaSYaaSaaaeaacqaHdpWCdaqhaaWcbaGaaG ymaaqaaiaaikdaaaaakeaacqaHdpWCdaqhaaWcbaGaaGymaaqaaiaa dshaaaGccqGHflY1cqaHdpWCdaqhaaWcbaGaaGymaaqaaiaadogaaa aaaOGaey4kaSYaaSaaaeaacqaHdpWCdaqhaaWcbaGaaGOmaaqaaiaa ikdaaaaakeaacqaHdpWCdaqhaaWcbaGaaGOmaaqaaiaadshaaaGccq GHflY1cqaHdpWCdaqhaaWcbaGaaGOmaaqaaiaadogaaaaaaOGaeyOe I0YaaSaaaeaacqaHdpWCdaWgaaWcbaGaaGymaaqabaGccqGHflY1cq aHdpWCdaWgaaWcbaGaaGOmaaqabaaakeaacqaHdpWCdaqhaaWcbaGa aGymaaqaaiaadshaaaGccqGHflY1cqaHdpWCdaqhaaWcbaGaaGymaa qaaiaadogaaaaaaOGaey4kaSYaaSaaaeaacqaHdpWCdaqhaaWcbaGa aGymaiaaikdaaeaacaaIYaaaaaGcbaGafq4WdmNbaebadaqhaaWcba GaaGymaiaaikdaaeaacaaIYaaaaaaakiabgsMiJkaaigdaaaa@8ECC@
    For solids the criterion becomes:
    F = 1 σ 1 t 1 σ 1 c σ 1 + 1 σ 2 t 1 σ 2 c σ 2 + 1 σ 2 t 1 σ 2 c σ 3 + σ 1 2 σ 1 t σ 1 c + σ 2 2 σ 2 t σ 2 c + σ 3 2 σ 2 t σ 2 c σ 1 σ 2 σ 1 t σ 1 c σ 1 σ 3 σ 1 t σ 1 c + σ 12 2 σ ¯ 12 2 + σ 31 2 σ ¯ 12 2 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9maabmaabaWaaSaaaeaacaaIXaaabaGaeq4Wdm3aa0baaSqaaiaa igdaaeaacaWG0baaaaaakiabgkHiTmaalaaabaGaaGymaaqaaiabeo 8aZnaaDaaaleaacaaIXaaabaGaam4yaaaaaaaakiaawIcacaGLPaaa cqaHdpWCdaWgaaWcbaGaaGymaaqabaGccqGHRaWkdaqadaqaamaala aabaGaaGymaaqaaiabeo8aZnaaDaaaleaacaaIYaaabaGaamiDaaaa aaGccqGHsisldaWcaaqaaiaaigdaaeaacqaHdpWCdaqhaaWcbaGaaG OmaaqaaiaadogaaaaaaaGccaGLOaGaayzkaaGaeq4Wdm3aaSbaaSqa aiaaikdaaeqaaOGaey4kaSYaaeWaaeaadaWcaaqaaiaaigdaaeaacq aHdpWCdaqhaaWcbaGaaGOmaaqaaiaadshaaaaaaOGaeyOeI0YaaSaa aeaacaaIXaaabaGaeq4Wdm3aa0baaSqaaiaaikdaaeaacaWGJbaaaa aaaOGaayjkaiaawMcaaiabeo8aZnaaBaaaleaacaaIZaaabeaakiab gUcaRmaalaaabaGaeq4Wdm3aa0baaSqaaiaaigdaaeaacaaIYaaaaa GcbaGaeq4Wdm3aa0baaSqaaiaaigdaaeaacaWG0baaaOGaeyyXICTa eq4Wdm3aa0baaSqaaiaaigdaaeaacaWGJbaaaaaakiabgUcaRmaala aabaGaeq4Wdm3aa0baaSqaaiaaikdaaeaacaaIYaaaaaGcbaGaeq4W dm3aa0baaSqaaiaaikdaaeaacaWG0baaaOGaeyyXICTaeq4Wdm3aa0 baaSqaaiaaikdaaeaacaWGJbaaaaaakiabgUcaRmaalaaabaGaeq4W dm3aa0baaSqaaiaaiodaaeaacaaIYaaaaaGcbaGaeq4Wdm3aa0baaS qaaiaaikdaaeaacaWG0baaaOGaeyyXICTaeq4Wdm3aa0baaSqaaiaa ikdaaeaacaWGJbaaaaaakiabgkHiTmaalaaabaGaeq4Wdm3aaSbaaS qaaiaaigdaaeqaaOGaeyyXICTaeq4Wdm3aaSbaaSqaaiaaikdaaeqa aaGcbaGaeq4Wdm3aa0baaSqaaiaaigdaaeaacaWG0baaaOGaeyyXIC Taeq4Wdm3aa0baaSqaaiaaigdaaeaacaWGJbaaaaaakiabgkHiTmaa laaabaGaeq4Wdm3aaSbaaSqaaiaaigdaaeqaaOGaeyyXICTaeq4Wdm 3aaSbaaSqaaiaaiodaaeqaaaGcbaGaeq4Wdm3aa0baaSqaaiaaigda aeaacaWG0baaaOGaeyyXICTaeq4Wdm3aa0baaSqaaiaaigdaaeaaca WGJbaaaaaakiabgUcaRmaalaaabaGaeq4Wdm3aa0baaSqaaiaaigda caaIYaaabaGaaGOmaaaaaOqaaiqbeo8aZzaaraWaa0baaSqaaiaaig dacaaIYaaabaGaaGOmaaaaaaGccqGHRaWkdaWcaaqaaiabeo8aZnaa DaaaleaacaaIZaGaaGymaaqaaiaaikdaaaaakeaacuaHdpWCgaqeam aaDaaaleaacaaIXaGaaGOmaaqaaiaaikdaaaaaaOGaeyizImQaaGym aaaa@C764@
    The criterion is considered to be reached when F = 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9iaaigdaaaa@3880@ . In fact, the damage variable corresponds to the criterion itself D = F MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaadAeaaaa@388E@ .
  3. Once the criterion is reached D = F = 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaadAeacqGH9aqpcaaIXaaaaa@3A4F@ , two behaviors can be set up:
    • If Ifail_sh = 0 or Ifail_so = 0, there is no stress softening and elements are never deleted. In this case, the failure criterion is purely visual using the output of the damage variable.
    • If Ifail_sh0 or Ifail_so0, a stress relaxation is generated to decrease the load carrying capacity of the element.
      σ ( t ) = f ( t ) σ d ( t r ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4WdiaacI cacaWG0bGaaiykaiabg2da9iGacAgaciGGOaGaamiDaiaacMcacqGH flY1caWHdpWaaSbaaSqaaiaadsgaaeqaaOGaaiikaiaadshadaWgaa WcbaGaamOCaaqabaGccaGGPaaaaa@4612@
      With f ( t ) = exp t t r τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaciOzaiGacIcacaWG0bGaaiykaiabg2da9iGacwgacaGG4bGaaiiC amaabmGabaGaeyOeI0YaaSaaaeaacaWG0bGaeyOeI0IaamiDamaaBa aaleaacaWGYbaabeaaaOqaaiabes8a0naaBaaaleaaciGGTbGaaiyy aiaacIhaaeqaaaaaaOGaayjkaiaawMcaaiaayIW7caaMi8oaaa@4F79@ and t t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDaiabgwMiZkaadshadaWgaaWcbaGaamOCaaqabaaaaa@3EAE@ .
      Where,
      t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDaaaa@3ACC@
      Time.
      t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDamaaBaaaleaacaWGYbaabeaaaaa@3BEF@
      Start time of relaxation when the damage criteria is assumed.
      τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3E98@
      Time of dynamic relaxation.
      σ d t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaaC4WdmaaBaaaleaacaWGKbaabeaakmaabmGabaGaamiDamaaBaaa leaacaWGYbaabeaaaOGaayjkaiaawMcaaaaa@3FF2@
      Stress tensor when the criterion is reached.
      When the stresses reach 1% of the stress value at the beginning of the failure, the element is deleted. This is necessary to avoid instabilities coming from a sudden deletion of an element and a failure “chain reaction” in the neighboring elements. Even if the failure criterion is reached, there will be no element deletion with the default value of τ max = 1.0 E 20 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaGccqGH9aqp caaIXaGaaiOlaiaaicdacaWGfbGaaGOmaiaaicdaaaa@440F@ . Therefore, it is recommended to define a value for τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3E98@ 10 times larger than the simulation time step.
  4. To avoid “chain reaction” when deleting elements, you can also define a stress tensor filtering frequency Fcut. Thus, the stress tensor used to calculate the HOFFMAN criterion is first be filtered according to:
    σ n + 1 f i l t = α σ n + 1 + 1 α σ n f i l t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4WdmaaDa aaleaacaWGUbGaey4kaSIaaGymaaqaaiaadAgacaWGPbGaamiBaiaa dshaaaGccqGH9aqpcqaHXoqycaWHdpWaaSbaaSqaaiaad6gacqGHRa WkcaaIXaaabeaakiabgUcaRmaabmaabaGaaGymaiabgkHiTiabeg7a HbGaayjkaiaawMcaaiaaho8adaqhaaWcbaGaamOBaaqaaiaadAgaca WGPbGaamiBaiaadshaaaaaaa@506A@
    With α = 2 π F c u t Δ t 2 π F c u t Δ t + 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdeMaey ypa0ZaaSaaaeaacaaIYaGaeqiWdaNaeyyXICTaamOramaaBaaaleaa caWGJbGaamyDaiaadshaaeqaaOGaeyyXICTaeuiLdqKaamiDaaqaai aaikdacqaHapaCcqGHflY1caWGgbWaaSbaaSqaaiaadogacaWG1bGa amiDaaqabaGccqGHflY1cqqHuoarcaWG0bGaey4kaSIaaGymaaaaaa a@54D6@
    Where, Δ t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam iDaaaa@3853@ is the current timestep.
    If a filtering frequency is not defined (Fcut= 0.0), the filtering effect is deactivated.
  5. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
  6. The reserve/safety factor can be plotted using /H3D/ELEM/FAILURE/ID=FAILID/MODE=1. The failure index is obtained using /H3D/ELEM/FAILURE/ID=FAILID alone.
