/FAIL/SPALLING
Block Format Keyword Describes the Spalling and Johnson-Cook failure model.
/FAIL/SPALLING/mat_ID/unit_ID
D1 D2 D3 D4 D5
ε ˙ 0 Pmin Ifail_so
Optional Line
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
D1 1st parameter.
(Real)
D2 2nd parameter.
(Real)
D3 3rd parameter.
(Real)
D4 4th parameter.
(Real)
D5 5th parameter.
(Real)
ε ˙ 0 Reference strain rate.
(Real)
[ 1 s ]
Pmin Pressure cutoff.
(Real < 0)
[ Pa ]
Ifail_so Failure model flag.
= 1
For each integration point, spalling is allowed: once spalling is detected (P = Pmin), the deviatoric stress is set to zero and pressure is required to be compressive.
= 2
For each integration point, spalling is allowed and solid element is deleted, if D = ∑ Δ ε p ε f ≥ 1 for one integration point or layer.
= 3
For each integration point, spalling is allowed and the deviatoric element stress tensor vanishes, if D = ∑ Δ ε p ε f ≥ 1 .
= 4
Solid element is deleted, if D = ∑ Δ ε p ε f ≥ 1 or P = Pmin for one integration point.
(Integer)
fail_ID Failure criteria identifier. 3
  1. This failure model is available for Solid only.
  2. In this model two models are combined. The first one is the Johnson-Cook failure model, and the second one is the Spalling model (Spall is detected if (P = Pmin), the deviatoric stress is set to zero and pressure is required to be compressive).
    ε f = [ D 1 + ​ D 2 ​     exp ( D 3 σ * ) ] [ 1 + D 4 ln ( ε ˙ * ) ] [ 1 + D 5 T * ]
    Where,
    σ * = σ m σ V M
    ε ˙ * = ε ˙ ε ˙ 0
    T * MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaiaacQ caaaa@377E@
    Is computed in the material law, if this one is thermo plastic, like /MAT/LAW4 (HYD_JCOOK).
  3. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
  4. Two failure modes can be displayed using /H3D/SOLID/FAILURE/ID=Fail_ID/MODE=ALL
    • Mode 1: Johnson-Cook criterion
      ∑ Δ ε p ε f
      Where, Δ ε p is the plastic strain increment.
    • Mode 2: Pmin criterion
      m i n P , 0 . 0 P m i n
      Where, P is the pressure.
