Set Data Save
You can configure settings that determine the simulation data saved, the type of data to be saved, save interval, and data compression.
In the Simulator Settings dialog box, specify the
following details:
| For | Specify |
| Data Save | |
| Target Save Interval | Select how often data should be written out to a file. This determines the number of data points (the points at which data is collected from the simulation for analysis). |
| Synchronized Data Save | Indicates the actual time at which the data will be saved. This is usually the same as the target save interval, but may differ depending on the Time Step. |
| Data Points | Indicates the number of data points as determined by the target save interval. It is calculated by dividing the total run time by the target save interval. |
| Iterations per Data Point | Indicates the number of simulator iterations for each data point. |
| Compress Data | Select the checkbox to reduce the size of the saved data. |
| Selective Save | Select the checkbox to enable selective save. For more information about configuring selective save, see Selective Saves. |
