Export Simulation Results
While running simulations, you can export simulation results to assess the behavior of the simulation during processing without the need for stopping and post-processing in EDEM Analyst.
Set up a config query in the .
Optionally, you can set up multiple export data configs. However, only one config can be used to output results in the Simulator.
Select the Output Results checkbox and select one of the
available export data configs.
The data exported is governed by the selected Configuration ID. The exported data corresponds directly to the query that you have defined in the Analyst, including the name and location of the
csvfile. For more information about exporting simulation results, see Export Results Data.
