Braided (Tyni) Layer
This option defines a braided shield layer using the Tyni model.
- Shield definition label
- A name for the shield layer definition.
- Weave definition
- Weave angle ψ (degrees)
- The weave angle of the shield.
- Number of carriers (m)
- The number of the carriers in the braided shield.
- Number of filaments (n)
- The number of filaments in each carrier.
- Diameter (d)
- The diameter of the filament.
- Metallic material
- PEC
- Select this option to set the shield of the filaments to PEC.
- Material label
- The label of the metallic material (as defined in the DI card) to be used for the shield.
