ACU-T: 6103 AcuSolve - EDEM Bidirectional Coupling with Heat Transfer
Tutorial Level: Beginner
This tutorial introduces you to the workflow for setting up and running a basic bidirectional coupling (two-way) simulation with heat transfer using AcuSolve and EDEM. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and have a basic understanding of HyperMesh CFD, AcuSolve, and EDEM. To run this simulation, you will need access to a licensed version of HyperMesh CFD, AcuSolve, and EDEM.
Problem Description
The model consists of a cylindrical pipe with a 45-degree bend. The radius of the pipe is 0.25 m and the particle inlet is located midway through the length of the pipe.
Accordingly, the tutorial consists of two parts:
- AcuSolve setup and geometry export
- EDEM setup and simulation
The AcuSolve model will be set up using HyperMesh CFD. Once the AcuSolve setup is complete, the EDEM deck with the geometry will be exported from HyperMesh CFD. This input deck will be opened in EDEM and will be used to complete the EDEM setup. Once the EDEM deck is set up, you will launch the coupled simulation.
Two different bulk materials used in the EDEM simulation and their properties are listed below:
| Name | Density (kg/m3) | Particle radius (m) | Average mass of individual particle (kg) | Rate of generation (particles per sec) |
| Heavy particle | 900 | 0.03 | 0.1 | 100 |
| Light particle | 100 | 0.03 | 0.01 | 100 |
The thermal material properties used for the particles are listed in the table below:
| Name | Thermal conductivity (W/m-k) | Specific heat capacity (J/kg-K) | Temperature (K) |
| Particles | 1.4 | 840 | 363 (initial) |
| Walls | 30 | - | 293 |
Part 1 - AcuSolve Simulation
Figure 3.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T6103_windshifter_heat.hm and click Open.
- Click .
Save the database as windshifter_heat in
the same directory as the other input files.
Validate the Geometry
Set Up Flow
Figure 5.
The Setup dialog opens. - Under the Physics models setting, select the Multiphase flow radio button.
- Change the Multifluid type to Bidirectional EDEM Coupling.
Click the Eulerian material drop-down menu and select Material
Library from the list.
You can create new material models in the Material Library.
In the Material Library dialog, select EDEM 2 Way
Multiphase, switch to the My Material
tab, then click
to add a new material model.
- In the microdialog, click EDEM Bidirectional Material in the top-left corner and change the name to Air-Particle.
- Set the Carrier field to Air (if not set already).
Set the drag model and the drag coefficients as shown in the figure
below.
Figure 6.
- Close the material model microdialog and then close the Material Library dialog.
- In the Setup dialog, set the Eulerian Material to Air-Particle.
- Set Time step size and Final time to 0.001 and 1, respectively. Select Spalart-Allmaras for the Turbulence model.
- Verify that Gravity is set to 0, 0, -9.81.
Activate the Heat transfer checkbox.
Figure 7.
Click the Solver controls setting and set the Minimum
and Maximum stagger iterations to 2 and
4, respectively.
Figure 8.
- Close the dialog and save the model.
Assign Material Properties
Figure 9.
- Verify that Air-Particle has been assigned as the material.
On the guide bar, click
to exit
the tool.
From the Flow ribbon, Profiled
tool group, click the Profiled Inlet tool.
Figure 10.
Click on the inlet face highlighted in the figure below. In the microdialog, enter a value of 20 m/s
for the Average velocity, 293 K for Temperature, and
1.0 for the Carrier fluid volume fraction.
Figure 11.
to execute
Click the Outlet tool.
Figure 12.
Select the face highlighted in the figure below then click
on the
guide bar.
Figure 13.
Click the No Slip tool.
Figure 14.
- Select all the faces except the inlet and outlet faces.
In the microdialog, click the
Temperature tab and set the parameters as shown in
the figure below.
Figure 15.
to execute the command and remain in the
tool.
Select the face highlighted in the figure below. In the microdialog, click the Temperature tab
and set the parameters as shown.
Figure 16.
Click
on the guide bar.
In the Boundaries legend, right-click on Wall 1 and
rename it to Particle Inlet.
You will use this surface as a reference geometry to create a particle factory in EDEM. Hence, you are placing this surface in a different geometry group.
Click
on the guide bar.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 17.
The Meshing Operations dialog opens. -
Change the Average element size to 0.3.
Figure 18.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Define Nodal Outputs
Once the meshing is complete, you are automatically taken to the Solution ribbon.
From the Solution ribbon, click the Field tool.
Figure 19.
The Field Output dialog opens. - Check the box for Write Initial Conditions.
Set the Time step interval to 10.
Figure 20.
Export the Solver Deck
- From the menu bar, go to .
- Name the file windshifter_heat and make sure that AcuSolve (*.inp) is selected as the file type.
- Click Save.
Part 2 - EDEM Simulation
Start Altair EDEM from the Windows start menu by clicking .
Open the EDEM Input Deck
As mentioned earlier, when the AcuSolve simulation was launched, HyperMesh CFD created a set of EDEM files in the problem directory. You will open that EDEM input deck and setup the DEM simulation.
- In the Creator tab in EDEM, go to .
In the dialog, browse to the AcuSolve problem
directory and open the windshifter_heat.dem file located in the EDEM
folder.
The geometry is loaded.
Click the Environment tab under the Creator Tree,
uncheck Auto Update from Geometry, and then check the box
again to fit the geometry within the boundary.
Figure 21.
Figure 22.
Define the Bulk Materials and Equipment Material
In this step, you will define the material models for the heavy and light bulk material and the equipment material.
- In the Creator Tree, right-click Bulk Material and select Add Bulk Material.
- Rename the material to Heavy.
In the Creator Tree, set the Solids Density property to
900 kg/m3.
You will use the default values for other properties for this tutorial.
Figure 23.
Click
below Interaction to define the
interaction properties for collisions among the heavy particles. In the dialog,
click OK.
- In the Creator Tree, right click Heavy and select .
- Rename the particle to Heavy particle.
- Under Heavy particle, click Properties.
In the Heavy particle Spheres panel, set the Physical Radius of both the
spheres to 0.03 m and press Enter.
Figure 24.
In the Creator Tree, click Calculate Properties.
Figure 25.
- Rename the material to Light.
100 kg/m3.
Figure 26.
Click
select Heavy and then click OK.
Click
again to define the interaction
properties for collisions among the light particles. In the dialog, select
Light and then click OK.
- In the Creator Tree, right click on Light and select .
- Rename the particle to Light particle.
- Under Light particle, click Properties.
In the Light particle Spheres panel, set the Physical Radius of both the
Figure 27.
Figure 28.
- In the Creator tree, right-click Equipment Material and select Add Equipment Material. Rename it to Steel.
- Set the Density to 7800 kg/m3.
Click
Click
- Save the model.
Create the Particle Factory
- Expand Geometries under the Creator Tree tab. Next, right-click on the Particle Inlet surface group and select .
- Rename the new geometry section to Particle_factory.
- Right-click on the Wall geometry section in the Creator Tree and select Merge Geometry(s).
- In the Merge Geometry dialog, select the Particle Inlet then click OK.
Click on the Wall geometry section, set the Type to
Physical, and the Material to
Steel (if not set already).
Figure 29.
- In the Creator Tree, click the Inlet section and change the Type to Virtual.
- Similarly, change the Type to Virtual for the Outlet and Particle_factory sections.
Under Particle_factory, click Transform. Set the
X-Position to 0.035 m
Figure 30.
Note: Set the Opacity value to 0.2 to see the transformed surface location inside the pipe geometry.This is done to make sure that the particles are generated inside the fluid domain.
Define the Heat Transfer Paramaters
- In the Creator Tree, click on Physics.
- Set the Interaction drop down to Particle to Particle and click Edit Contact Chain.
In the dialog, activate Heat Conduction and click
OK.
Figure 31.
In the Physics tab, click Heat Conduction then click
Figure 32.
In the dialog, set the Thermal conductivity of both Heavy and Light particles
to 1.4 W/mK then click OK.
Figure 33.
- In the Physics tab, change the Interaction to Particle to Geometry and click Edit Contact Chain.
- In the dialog, activate Heat Conduction and click OK.
In the dialog, set the thermal conductivity of the particles to
1.4 W/mK and the conductivity and temperature of the
wall to 30 W/mK and 293 K,
respectively. Click OK.
Figure 34.
- In the Physics tab, change the interaction to Particle Body Force.
- Click Edit Contact Chain.
- In the dialog, activate Temperature Update then click OK.
In the Physics tab, click Temperature Update then click
In the dialog, set the specific heat capacity for both the particle types to
840 J/kgK then click OK.
Figure 35.
- Save the model.
Define the Particle Factory
Now that the bulk material, geometry sections, and equipment materials are defined, you need to create a particle factory to generate the particles. You will create one factory for each bulk material.
- In the Creator Tree, right-click on Particle_factory and select Add Factory.
- Rename the new factory to Heavy factory.
Set the particle generation parameters as shown in the figure below.
Figure 36.
Click
besides Velocity, set the
X-velocity to 1 m/s, then click
OK.
Click
besides Temperature, set the value to
363 K, then click OK.
Note: The fields for Temperature and Heat Flux will not be visible unless heat transfer properties are defined. - Repeat steps 1-5 to create another factory named Light factory using the same parameters but with Light as the Material.
Define the Environment
In this step, you will define the extents of the domain for the EDEM simulation and the direction of gravitational acceleration.
- In the Creator Tree, click Environment.
Activate the checkbox for Auto Update from Geometry (if
not already selected).
When a moving particle touches the bounding faces of the domain (environment), it will be removed from the simulation.
- Activate Gravity and set the z-value to -9.81 m/s2.
- Save the EDEM deck.
Define the Simulation Settings
Click
in the top-left corner to go to
the EDEM Simulator tab.
- In the Simulator Settings tab, set the Time Integration scheme to Euler and de-activate the Auto Time Step checkbox.
Set the Fixed Time Step to 2.5e-5 s.
Note: Generally, a value of 20-40% of the Rayleigh Time Step is recommended as the time step size to ensure stability of the DEM simulation.
- Set the Total Time to 1 s and the Target Save Interval to 0.01 s.
Set the Cell Size to 4 R min.
Generally, a value in the range of 3-6 Rmin is recommended as the optimum cell size.
Set the Selected Engine to CPU Solver and set the Number
of CPU Cores based on availability.
Figure 37.
- Once the simulation settings have been defined, save the model.
Submit the Coupled Simulation
Start the coupling server by clicking Coupling Server in
EDEM.
Figure 38.
Once the Coupling server is activated, the icon changes.Figure 39.
- Return to HyperMesh CFD.
Figure 40.
- Expand Default initial conditions, uncheck Pre-compute flow and set the velocity values to 0. Uncheck Pre-compute Turbulence.
- Set the Temperature to 293 K.
Click Run to launch AcuSolve.
Figure 41.
Once the AcuSolve run is launched, the Run Status dialog opens. -
In the dialog, right-click on the AcuSolve run and
select View log file.
If the coupling with EDEM is successful, that information is printed in the log file.
Figure 42.
Once the simulation is complete, the summary of the run time is printed at the end of the log file.Figure 43.
Analyze the Results
AcuSolve Post-Processing
In HyperMesh CFD, right-click on the AcuSolve run in the Run Status
dialog and select Visualize results.
Figure 44.
The results are loaded in the Post ribbon. -
Click the Slice Planes tool.
Figure 45.
Select the x-z plane as highlighted in the figure below.
Figure 46.
In the slice plane microdialog, click
to
create the slice plane.
- In the display properties microdialog, set the display to temperature and activate the Legend toggle.
- Change the bounds of the legend to 293 and 363.
Click
and set the Colormap name to Rainbow
Uniform.
Figure 47.
Click
on the guide bar.
In the Post Browser, turn off the visibility of
Flow Boundaries by clicking on its icon.
Figure 48.
Select the Left face on the view cube to align the model
to the x-z plane.
Figure 49.
Click
on the animation toolbar to view the animation of
the temperature contour.
Figure 50.
- To plot the volume fraction edem particle variable, right-click on Slice Plane 1 in the Post Browser and select Edit.
- In the display properties microdialog, change the display variable from temperature to volume fraction edem particle and the legend bounds to 0 and 0.2190.
Click
on the guide bar.
Click
to start the animation.
Figure 51.
EDEM Post-Processing
Once the EDEM simulation is complete, click
the EDEM Analyst tab.
- In the Analyst Tree, expand and then click Wall.
Verify that the Display Mode is set to Filled and set
the Opacity to 0.2.
Figure 52.
- In the Analyst Tree, click Particles.
- Set the coloring to Temperature.
- Activate the Auto Update checkboxes for both the Min and Max Value.
- Activate the Show Legend checkbox.
Click Apply All.
Figure 53.
On the menu bar, set the time to
0 by clicking:
Figure 54.
Set the View plane to + Y.
Figure 55.
In the Viewer window, set the Playback Speed to 0.1x and
then click
to play the particle flow animation.
Figure 56.
Observe that particles which are at a higher temperature at the time generation become colder as they exchange energy with the fluid phase.
Summary
In this tutorial, you learned how to set up and run a basic AcuSolve-EDEM bidirectional (two-way) coupling problem with heat transfer. In the first part, set up the AcuSolve model in HyperMesh CFD and exported the geometry. Next, you imported the EDEM input files created by HyperMesh CFD and set up the EDEM model. You learned how to set up the thermal properties for the particles as well as their interaction with other particles and equipment. Once the coupled simulation was completed, you learned how to create animations in both HyperMesh CFD Post and EDEM Analyst.
