hgtrans control GetCompressionLevel
Gets the current compression level for all data channels.
HyperGraphTrans Tcl Query
This command gets the level of lossless compression level that will be used when writing data channels to the output file. By default, the level is set to “high,” the maximum, which is slower but provides the best compression. Other possible levels include: “none”, “low”, and “medium”. The “medium” level gives the best trade-off between size and speed.
Set hgtrans to use a compression level of “none” and then
reads back that
value.
hgtrans control SetCompressionLevel none
hgtrans control GetCompressionLevelErrors
None.
Keywords
get compression level
