hgtrans control SetCompressionLevel
Sets the compression level for all data channels.
hgtrans control SetCompressionLevel level
HyperGraphTrans Tcl Modify
This command sets the lossless compression level used when writing data channels to the output file. By default, the level is set to “high,” the maximum, which is slower but provides the best compression.
- level
- Level can be any of the following:
- none
- Causes the output to be written in uncompressed form.
- low
- medium
- Gives the best trade-off between size and speed.
- high
Cause hgtrans to read everything from a MADYMO file
called “ANGACC” and save it to “ANGACC.abf”, using
no
compression.
hgtrans control SetFile "ANGACC"
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control SetCompressionLevel none
hgtrans control StartTranslationError
None.
Keywords
set compression level
