hgtrans control GetNumberOfLabelAliasRules
Gets the number of currently defined aliases.
hgtrans control GetNumberOfLabelAliasRules subcase, datatype, level
HyperGraphTrans Tcl Get
This command gets number of currently defined aliasing rules for a specificed subcase, datatype and level.
- subcase
- The name of the subcase in which to apply the rule.
- datatype
- The name of the datatype in which to apply the rule. (Does not apply if the level is “subcase”.)
- level
- The level of labels at which to apply the rule.
- datatype
- request
- component
Adds a rule to change the word “head” in all request names to its Spanish equivalent
“cabeza” and then check the number of defined aliases (should be
one).
hgtrans control AddLabelAliasRule "head" "cabeza" "Subcase 1" "Displacement" request
hgtrans control GetNumberOfLabelAliasRules "Subcase 1" "Displacement" requestErrors
None.
Keywords
get channel alias
