hgtrans control GetTimeScaleFactor
Gets the current scale factor for all time channels.
HyperGraphTrans Tcl Query
This command gets the scale factor that will be applied to time channels. By default, the factor is one.
Set hgtrans to use a time scaling factor of 1000 and then reads back that
value.
hgtrans control SetTimeScaleFactor 1000
hgtrans control GetTimeScaleFactorErrors
None.
Keywords
get time scale factor
