hgtrans control StartTranslation
Begins the process of reading from the input file and writing selected channels to the output file.
HyperGraphTrans Tcl Action
This command causes the translation process to begin, using the options previously set by other commands and by reading in the configuration file. Translation will proceed until all selected channels from the input file have been translated.
Cause hgtrans to read everything from a MADYMO file
called “ANGACC” and save it to
“ANGACC.abf”.
hgtrans control SetFile "ANGACC"
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
An error will be generated if the input file cannot be read or if the output file cannot be written.
Keywords
start translation
