hgtrans control SetEnd
Sets the last data point index to be translated.
hgtrans control SetEnd index
HyperGraphTrans Tcl Modify
This command sets the index of the last step to read from each channel in the file. It is primarily used to filter out later data points that are not significant. The index is one-based.
- index
- index must be an integer greater or equal to one. The special value of negative one is taken to mean that all values should be read.
Cause hgtrans to read everything from a MADYMO file
called “ANGACC” and save it to “ANGACC.abf”, up to
time step
100.
hgtrans control SetFile "ANGACC"
hgtrans control SetEnd 100
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
If the starting index is higher than the last data value index present, no data will be translated.
Keywords
set end
