poIPost AddResultMathAnalysis
Adds a model and result pair to HyperView and enables result math.
poIPost_handle AddResultMathAnalysis tmpl mfile rfile mreader rreader add_resfiles
HyperView Tcl Modify
This command adds a model and result pair to HyperView and
enables result math. The result math operations which are available will depend on the
template name specified. The Model reader name and Result reader name arguments are
optional.
Note: If the AddModel and SetResult
commands are used, result math will not be enabled.
- tmpl
- The result module template name (for example, Standard, Advanced, NVH).
- mfile
- The path of the model file.
- rfile
- The path of the result file.
- mreader (Optional)
- Specifies the reader name which will be used to read the model file.
- rreader (Optional)
- Specifies the reader name which will be used to read the result file.
- add_resfiles (Optional)
- Specifies the path of additional result files to be loaded along with the model file and result file. The additional result files are separated by a semicolon (;).
To add a new model and result file with result math
enabled:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle AddResultMathAnalysis Standard c:/model.dat c:/result.op2 0 0 "c:/result2.op2;c:/result3.op2;c:/result3.op2"
hwi CloseStackErrors
Returns the ID of the model added, or an error code (0) if a model/result pair could not be added.
