poIPost GetAdvancedQueryHandle
Gets the handle to the advanced query.
client_handle GetAdvancedQueryHandle advquery_handle id
HyperView Tcl Query
This command is used to get the advanced query handle with a specified ID.
- advquery_handle
- Gets the advanced query handle.
- id
- Accepts the ID of the advanced query which is an integer.
To get the advanced query
handle:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle distance_rule_handle $ruleID
distance_rule_handle SetDistance "20"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
the client handle does not exist anymore.
