poIPost RemoveBestView
Removes the BestView.
client_handle RemoveBestView id
HyperView Tcl Modify
This command removes the BestView with a specified ID.
- id
- The ID of the BestView already existing in the post handle.
To remove BestViews from a given advanced query
result:
post_handle RemoveBestView 1Errors
This command returns 0 if successful, otherwise and error code.
