poIPost ExportH3D
Exports an H3D format file.
poIPost_handle ExportH3D filename options
HyperView Tcl Modify
This command exports an H3D format file.
- filename
- The complete path of the H3D file to be written.
- options (Optional)
- The options available when exporting an H3D file. Preface the option with "no" to toggle the default.
To write an H3D
file:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
myPostName ExportH3D C:/temp/temp.h3d "nohtml compress 0.0002 noentitysets"Errors
Returns 0 if successful, otherwise an error code.
