poIPost GetBestViewHandle
Gets the handle of the best view.
post_handle GetBestViewHandle param id
HyperView Tcl Query
This command gets the handle of the best views present in the current post client with a given ID.
- param
- Specify a handle name.
- id
- Specify the ID of the best view for which the handle is needed.
To get the handle of the best view for the newly created best
view:
post_handle GetBestViewHandle bestview_handle [post_handle AddBestView]To get the handle of the best view already created in the post
client:
post_handle GetBestViewHandle bestview_handle 10Errors
This command returns the handle name if successful or an error code.
