poIPost GetQueryRuleHandle
Gets the query rule handle from the client.
client_handle GetQueryRuleHandle queryrule_handle id
HyperView Tcl Query
This command is used to get the query rule handle from the client.
- queryrule_handle
- Returns the queryrule_handle for the respective query rule.
- id
- Accepts the rule IDs.
To get the query rule
handle:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
the post handle does not exist anymore.
