2025
The Aerospace menu provides you with access to various aerospace tools.
View new features for Altair HyperWorks 2025.
The Report Configurator tool allows you to quickly create a Word document or pictures.
Fringe post-processing using different volume averaging methods.
The NVH utilities are now available only via the HyperMesh NVH menu bar.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing the multicore profile for post processing results from certain solvers and crash use cases.
The Developer ribbon contains tools for automation and customization.
