Saving Model Files
From the File menu select .
Or
From the Home tools, Files tool group, click the Save Model tool.Figure 1.
Note: If the model in the data base is a new model, a dialog will be displayed. However if the model already has a file name, it will be saved directly (no dialog will be displayed). -
From the Save As Model dialog, specify a file name and
click Save.
The model is saved.
