Test Models
Use the Model Testing tools to test models and review test results.
- Mean Absolute Error (MAE)
- The MAE metric is a valuable metric to assess the quality of machine learning model predictions because the metric is easily interpreted. MAE is in the units of the predicted quantity, so it means that (on average) any given prediction is off by this amount of error.
clear all
clc
A= 5/30;
B= 5;
d = 8.235;
x = -20:1:60;
rand('seed',4);
y = A*x + B + d*rand(size(x)).*(rand(size(x))-0.5);
yl = A*x + B;
function yf = func(p,x)
yf = p(1)*x + p(2);
end
p = lsqcurvefit(@func,[A,B],x,y)
yl2= p(1)*x + p(2);
scatter(x,y);
line(x,yl2);
MAE=mean(abs(yl2-y))
From the PhysicsAI ribbon, select the Test
Machine Learning Model tool.
The Test Model dialog opens. -
Select a model and Dataset.
Figure 3.
Click OK.
The Model Testing dialog opens.Tip: You can also open the Model Testing dialog by selecting the Review Test Results tool.
Figure 4.
- Click Detailed Report to open the View Score Report.
- In the Model Testing dialog, select a Run ID and click Display File to view the results in the modeling window.
- Close the Model Testing dialog.
